i've captured an old VHS with my PVR150 mpeg card in the best quality possible then compressed the video with virtualdub mpeg2 to h.264 in .avi
I couldn't do the audio at the same time cause the codec i wanted wasn't showing up in the audio compression field so i just slip the wav off and compressed it on my own and removed some hiss in sound forge.
BUT if i try to select the .mp3 audio file and then convert the video to h.264 with the mp3 file attached the video blow's up from 10mb to 365mb????? wtf?
So, i compressed video, h.264 video in a .avi shell on it's own with no sound, and my compressed sound in .mp3 but how do i join them ? I tried opening the compressed video back up in virtualdub to just do a direct stream copy of it and the audio selected from the file but it won't read the video after it's compressed to h.264 so i'm lost.
The only other way i've found to do it is to convert the .mpg capture to an uncompressed RGB in .avi that's 60gb and use gordian knot to compress the video to h.264 while it mux's the pre compressed audio aswell.
Help![]()
get a real keyboard, Kinesis
In VirtualDubMod, open your x.264 AVI file, add the mp3 audio file, put audio and video both in Direct Stream Copy mode, save as AVI.
virtualdub mod will let me import it in direct stream copy mode but i don't think you can control audio in virtualdub mod
virtualdub mpeg2 won't import the video at all i just get this (attached pic)
get a real keyboard, Kinesis -
ok, nevermind i got it in virtualdub mod, i forgot about the stream list thingy
But now i'm having trouble and getting error's when i try to encode more then 60 seconds of video
Join AVI file
By czgirb in forum Video ConversionReplies: 3Last Post: 19th Jun 2011, 22:53 -
MP4 file (h.264 format) to avi help
By hak741 in forum Video ConversionReplies: 6Last Post: 18th Nov 2010, 01:51 -
Need a .bat file to join avi files
By aat666 in forum Newbie / General discussionsReplies: 2Last Post: 7th Oct 2010, 07:46 -
AVC FILE to AVI/MP3 File: How to Convert?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 25th Jul 2007, 22:49 -
Need to join a avi and divx file, not sure how
By MattP2007 in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2007, 11:24
