What would experts recommend as the best way to convert a VIDEO_TS folder of video files to an AVI file please?
The context is that I have a program called MemoriesOnTV that does a neat job of applying Ken & Burns pan/zoom effects flexibly to my photo JPGS. It creates either a finished DVD or the usual VOB folders on HD. I don't rate its other features very highly, so I want to do my movie editing elsewhere. So I want to do the Ken & Burns and then convert the VOB folder to an AVI that I can import to another movie editing program.
Terry, West Sussex, UK
You could use VOB2MPG, then run the MPEG through VirtualDub Mod and convert to HuffyUV, Pic Video or DV format. You can use the Panasonic DV Codec for DV format conversion. Then edit with whichever AVI editor you want. You would have to re-encode it once again to MPEG-2, then author it again for a DVD.
There will be some quality losses involved. You could just drop one VOB into VD Mod and convert that to AVI, then back again with an MPEG encoder to see how it will look before committing yourself.
And I'm not a expert.
Thanks, very helpful. I'll try those suggestions asap.
Video_TS to AVI
By aliasrobert999 in forum Video ConversionReplies: 1Last Post: 9th Mar 2011, 02:16 -
VIDEO_TS to .avi conversion help?
By itsjamesd in forum MacReplies: 4Last Post: 10th Nov 2010, 14:11 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 20:40 -
Video_TS to Avi encoding
By macbuz in forum MacReplies: 9Last Post: 16th Jan 2009, 15:59 -
convert VIDEO_TS to avi
By SeveralButchersApron in forum MacReplies: 14Last Post: 2nd Jun 2008, 20:50
