my macpro arrived yest and its the best
but it came with a sony dvd-r dl DW-D150a
Ive put a pioneer DVR-111D in the second bay
it was only 31$$ delivered (not the macpro!)
how does the sony stack up? ive always had pioneer
if its ifffyy Id get another 111D for 31 and pass the sony on to somebody.
cheers
rotuts
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
IMO, five things are important for any Mac DVD drives, in this order.
- Is it iApps supported? If Apple installed it, this drive should be okay. (System Profiler > Hardware > Disc Burning > Burn Support: Yes)
- Dual Layer support. Apple's new SuperDrive does.
- How is the media support? Can you burn low speed if you want to? Is there a good track record of firmware updates which to allow high speed burns on new types of media? This is often brand specific. And don't expect it to come from Apple...
- Can it be flashed RPC1 (region free)? With newer drives there could be some time before a patch is available. Not sure about Sony drives, but Pioneer aid is good in this department.
- Is it speedy? With a new machine, this should be okay. Apple says 16x. I see mostly 8x discs in stores, so no problem there.
How does the sony stack up? You tell us! You're the one with the brand new flashy drive...
Ill keep an eye on it. but don't hold your breath Im not a heavy user!
BTW know how I can find out if the Pioneer needs flashing?
I have a Pioneer 110 in my G4 and it wouldn't flash properly some of you may recall that thread. so for 31 dollars US deliverd I got the 111 for the Pro and will pass the 110 along to the next user
it works fine but might not have the latest firmware
its going to take several days to migrate from the G4 to the Pro
then Ill try iMovie and import into iLife 6 and see what the sony does
Ill report back to this thread but I bet someone who does this moreofftern thatn I will have the info first.
BTW aside from a scarcity of Firewire ports on the back (1) its a fery fine machine it havs the finest internals iver ever seen in a Mac
drives just slide in, 2d optical about the same you have to attach a ribbon there
waiting for the Crucial RAM
cheers
rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
MacPro + IntensityPro + Xbox360 HELP!
By L00p in forum Capturing and VCRReplies: 0Last Post: 24th Apr 2010, 13:28 -
canopus ADVC-55 conversion analog to digital on MacPro
By morgankia in forum MacReplies: 3Last Post: 27th Oct 2009, 22:56 -
Avid Meridien playback strangeness on MacPro
By cbarduck in forum MacReplies: 1Last Post: 12th Aug 2009, 13:10 -
MacPar deluxe 'CPU' hog in a MacPro?
By rotuts in forum MacReplies: 9Last Post: 19th Oct 2007, 16:49 -
Cheapest DVD+RW or -RW, I think mine is dead, help!
By Abouna in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Jun 2007, 10:36
