  1. Can anybody help...
    I keep having trouble trying to burn an Mpg file that is 740mb onto a CDRW 700mb/80min cd as a VCD. I am running WinXP and using EZ CD Creator 5.0 Platinum...
    I am using a 4X Yamaha RW drive with the current Firmware...
    It was my understanding when burning VCD that it was interpreted in Minutes. So an 80min CD should accomodate a 800mb file. Is this not correct.
    Can somebody please tell me where the problem lies. And please dont say, "User Error"
    Thank you in advance.
    Jul 2001
    One Step From Hell
    Try NERO. Im able to get 822mb on a 80min cd.
  3. User Error.
    hehe anyways, sounds like your just trying to burn the MPG file as a DataCD, are you sure you are burning it as a VideoCD using the proper template?
    Apr 2001
    I would take a guess that it's due to the CD Creator software, and a lack of a restart before using it. It's a nasty program. The only one WORSE THAN NERO (and believe me, I've just made a night of bashing NERO, it's awful).
