Hey everyone! Maybe I never noticed before, but.....
I captured raw DV from the camera to my computer, I can see the comb lines in VirtualDub, but GSpot does not show me that the video is interlaced. In fact, all the indicators are greyed out. Am I missing something or just forgot something simple?
Thanks for all your help.
TEBRT
The little [Prog] and [I/L] icons do indeed refer to "Progressive" and "Interlaced" video, but they are there as indicators of the presence of those flags in MPEG files.
You're talking about DV, and there is no such flag in a DV-compressed file that tells whether it's Prog or IL. Best way to tell if it is or not is to look at it (whole string of frames).
However, the DV spec really ONLY expects interlaced. (It is working with SD video, so that makes sense).
There is an OpenDML extension to AVI (that DV files are usually saved under) that supports flagging whether a frame has 1 or 2 fields, but I don't know if AVI parsers such as Gspot have implemented recognition of it yet.
Scott -
Ah, thanks for the clarification. I think I just never noticed that before, or just plain got it confused with MPEG.
Thanks again!
TEBRT
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
GSpot and Mediainfo Help
By swampwizard in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2008, 09:03 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 08:01
