Gang,
I been using Nero for my backup of DVD to DVD-R movies, But i had to re-format pc, installed Nero again 6.0. Now every time im ready to burn my movie, the next step to click "burn" is grayed out. Even going through Nero Express or Nero Burning ROM options, it wont let me burn the movie the option is grayed out. Any ideas why this would be happing? I have an I/O Magic DVD-RW, work great. Using DVD-Shrink and DVDFAB Decrpt
Michael
Rochester,NY
Do you have two optical drives in your PC? If so, it may be using the CD-Rom drive by default, which obviously won't let you burn. If that's the case, you should be able to change this setting to reflect the burner.
Join the fight against Product Activation & DRM!
www.twistedlincoln.com -
Yes I do have two, but the selection is for the DVD-RW. I pretty good with this software, I wonder if I should download the two updates. That's one thing I did not do after I install the software from the disk that came with the DVD-RW. I was thinking firmware, but..................It was working great before re-format. I just cant remember from before if I did the updates. BRAIN FART it happens
Opinions on Nero for burning
By 44echo in forum Newbie / General discussionsReplies: 18Last Post: 24th Jun 2009, 19:36 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
