In avicodec it shows the list of codecs installed and direct show filters. You are able to disable them but i would like to know if there is any software that will uninstall them. .ax files and the regitsry entries as well.
My reason is because any avi file i create with vdubmod then use tmpgenc source creater to make my mpeg files audio is always out of sync. also any dvb capture to mpeg2 cannot be edited because anasyncrohnous timestamps.
anyway I believe its because of the mpeg filters installed.
You can try Codec Sniper. It will do some of that. I'm not sure that is causing your sync problem, though, but give it a try.
please list the virtualdub filters to remove vhs tape video noise
By perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 12:45 -
Avisynth filters to remove mosquito noise without softening
By AlanHK in forum RestorationReplies: 8Last Post: 7th Jan 2010, 23:49 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
Any good VirtualDub filters to remove common VHS color bands?
By rijir2001 in forum Newbie / General discussionsReplies: 1Last Post: 15th Nov 2008, 16:10 -
Remove Filters from Registry when file is missing
By swestner in forum Software PlayingReplies: 1Last Post: 12th Oct 2007, 11:38
