    Aug 2006
    Is there any way to backup my dvd's without using a computer?
    USA
    It depends. If they have DeCSS encryption or newer, you would need a computer with some programs to backup a DVD you own. This is typical of commercial DVDs.
    If they aren't encrypted and you own them, you can just copy them directly, even with a DVD recorder. Of course, you would need DVD media with enough capacity to copy them directly. Most pressed (commercial) DVDs are much larger than the standard single layer DVD (DVD-5) that can hold about 4.37GB. If you to use a dual layer DVD, they can hold about 7.95GB (DVD-9), large enough to fit the video from most pressed DVDs.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Short answer - no for commercial discs, yes for your own home mvies.
    Long answer - most HDD based DVD recorders have the facility to duplicate discs without re-encoding, however they will noy copy css protected discs. Disc duplication systems have the same limitations.
    Read my blog here.
    Aug 2006
    are there any hacks for existing recorders to allow backing up commercial dvd's?
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Yup wait for HBO
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Info here.
