Was recording the last episode of Big Brother, when halfway thru the show I got an error message saying that it would stop recording because the material was copywritted. Why would this suddenly just happen afeter already recording half the show? Any general info about Copy writted Broadcasts would also be helpful as I am still new to this. Thanks
Results 1 to 9 of 9
What DVD recorder are you using? My sister said it used to happen all the time with her Samsung. She bought a Toshiba and said it hasn't happened since.
I'd be interested in knowing if this has happened to anyone using a Hauppauge PVR150 capture device. I have one and it's never happened to me.
Originally Posted by AlecWest
The Happauge doesn't record any thing. It captures the program.
A software program such as Decrypter will strip the CP and ( some with Nero) will burn the disk.
But this is using a PC
[ryangarfield] I believe was speaking to a stand alone recorder and most if not all units, at present, will react to CP
If a Toshiba does not It would be a first . I don't belive CP was the problem with the Samsung. -
My stand alone DVD recorder is in fact a Samsung, i have recorded other broadcasts including other episodes of the same show( Big Brother) and have not had any problems. Just curious as to why it happened that one time. I was recieving the signal from a set of rabbit ears and maybe interpreted a signal as copy protection or something. Are there any channels in particular that copy protect their shows or is it just certain shows that have it or do most shows not have it?
Thats a typo from the japanese.. should have said "that it would stop recording because the material was half-witted". Doh! those pesky Koreans!
Probably just a signal glitch .. you should try having London Bus's going past interrupting your signal..Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Copy Protection
By Big Jake in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2010, 14:31 -
recording at an auto show
By famousDirector in forum Newbie / General discussionsReplies: 0Last Post: 1st Apr 2010, 00:24 -
Phillips 3576H - copy protection error when recording from TV
By robjv1 in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2009, 15:30 -
Archos AV500 recording / Macrovision protection
By bicklet in forum Portable VideoReplies: 3Last Post: 14th Mar 2008, 18:52 -
CD copy protection
By KingSeti in forum Off topicReplies: 14Last Post: 26th Feb 2008, 12:01
