my 2nd pc stop displaying anything and i changed the video card and it worked, i put the one in my computer, now both fans are not spinning, my video card works when put in either machine but the fan doesnt spin and the vid card does not work at all. what is going on??? anybody have any suggestions?
Your old video card quit, so you replaced it with a different one, and it works, but the fan on it doesn't? The old card doesn't work when put in a different computer, and neither does the fan on that card?
I'm not sure about video card fans, but most computer fans run on 12VDC. But I would think part of that card uses that voltage also. Otherwise, I would say there is a problem with your AGP socket. It doesn't seem likely that there is a problem with the 12VDC rail of the power supply or that the power supply is the problem or the rest of the computer would not function properly.
So far, it just seems like a strange coincidence that both fans quit. Maybe you can unplug the fan power connector on the dead card or remove the fan and see if it will plug into one of your motherboard fan connectors to test it. It may be a 2 pin plug though, and the MB connectors are mostly 3 pin.
Anyway, you need to test those fans by powering them from a different source and see it they are actually dead. If they aren't, then it could still be the power supply, the video cards, or the AGP connector on the MB. -
i have two vid cards, verto and chaintech, (each in one pc) i removed the verto and put it to replace the chaintech to see if it woudl work and it did but the fan didnt spin, everything else booted fine, now both cards dont have a spinning fan but the verto one boots fine and the chaintech doesnt boot at all.
any suggestions to my prob? -
Have your power supply tested for all voltages, especially the 12v.
Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
well what about my other pc? the psu is a different one and the fan is still not spinning but evertything works fine,
At the very least, you should always check to see of your power supply is putting out all the voltages that it is supposed to produce.
Sometimes, the lack of just one of those voltages can produce followon problems.
Then, or simultaneously, see if you can replace that fan on your vid card to see if that fan failed.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
mkvmerge GUI causes windows explorer to stop working
By codemaster in forum DVD RippingReplies: 8Last Post: 19th Oct 2012, 05:20 -
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
Why does doing video editing make other apps stop working?
By brassplyer in forum EditingReplies: 7Last Post: 13th Aug 2009, 11:01 -
Stop working and can't get it to work again...
By stillstanden in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 30th Jun 2009, 00:00
