I'm insterested in the ADVC110 that says it can operate without powersupply if you have 6pin firewire, how do I know this? also will the advc100 operate without PS if I have 6 or 8pin firewire? will I need to use the PS with the advc110 if I only have 4pin firewire?
Also what about the academic version of ADVC 110 is it a less capable version? or is just the same product promoted different?
Computers almost always have 6 pin FW connectors. They are about the size of a regular flat USB connector.
The ADVC-100 will only operate from a external power supply. I believe the 110 can use the 6 pin FW or an external supply. If you didn't have 6 pin FW, yes, you would need a PS.
I don't know about the academic version, maybe has a student discount. Since there is usually no software with the units, I doubt if the package is much different than the regular one. -
Originally Posted by redwudz
Just wanted to clarify since OP didn't specify laptop or not.
Photographs of what the 4-pin and 6-pin cable connectors look like here: http://www.amazon.com/gp/product/images/B000165AS0/ref=dp_image_text_0/104-2356297-308...&s=electronics
(Left is a 6-pin connector, right is 4-pin)John Miller -
Thanks, JohnnyMalaria, good point. I use a PCMCIA FW card in my laptop and it does have both types. I hadn't really paid any attention to other laptops. Laptop manufacturers probably don't really want the laptop to power external devices because of drawing the battery down too fast.
I have a FW 2.5 inch hard drive that won't run from the PCMCIA FW card without using a PS, but is fine with a desktop. Just needs a little more power than the PCMCIA card wants to output. -
academic version is the same, you just have to prove academic status.
B&H has better prices than academic
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=10899
what does this mean 'pins in the graph' RE: FLV file.
By talx in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2011, 11:26 -
How to disable MPC "could not render some of the pins in the graph" warnng?
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2011, 22:50 -
Media Player Classic could not render some of the pins...
By museamused in forum Software PlayingReplies: 0Last Post: 10th Dec 2010, 15:44 -
Why don't the new laptops have FIREWIRE??
By jbitakis in forum Capturing and VCRReplies: 12Last Post: 5th Aug 2010, 07:40 -
There is no common media types between these pins.
By Facelyss in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2010, 22:29
