I have a video file that came in two parts of a whole. I first tried to merge them with a VirtualDub program, but got an error message that said the audio formats of the two halves were different.
So, I ran each half through Goldwave, saving the audio tracks as .wav files, and, reattached them using TMPGEncoder, which naturally gave me two .m2v files, and, two .wav files (one for each half.) I realize now I should of joined them with the merge feature of TMPG, before runing it through Goldwave, (presuming that TMPG would have allowed this, since presumably, there were two diferent audio formats.)
But now that I have two .m2v, and, two .wav files, (and, two .avi, and, two .wav files) can I still use the merge feature of TMPG to join the two halves?![]()
Yes, you can.
1. Launch TMPGEnc. Click File & MPEG Tools...
2. Select Simple Multiplex. Choose the File Type, Video Source and Audio Source, click Run.
3. Once you have finish multiplexing all your video clips, select Merge & Cut.
4. Select all your clips... make they are in proper order, type output file name and click Run. -
to (mis?) quote a certain Hawaii-based detective of Chinese ancestry; "Thank you so much."
I thought I it was probably doable; just wasn't sure how.
Merging 2 mkvs into one
By leoficz in forum Video ConversionReplies: 8Last Post: 19th Apr 2012, 07:31 -
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
Merging mpeg
By drgt in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 06:19 -
MKV merging help
By snadge in forum Video ConversionReplies: 0Last Post: 25th Oct 2009, 14:19 -
Merging M2ts
By a1677c in forum EditingReplies: 1Last Post: 21st Jul 2007, 09:08
