  1. Hi I'm new to this and have some questions.
    I'll get to the point. I want to burn my movie files that are in avi format to CD. I want to burn to SVCD format. I have read through all the guides and surfed the web for info (there's much out there hehe).
    Well I have been using TMPGEnc to encode to SVCD format. I have made 4 coasters so far and figure I try to get some help before making more coasters. Visually it is great, but I am having problems with the audio. When finished encoding, it plays fine on my computer both visual and audio. But after I burn it to disc (with Nero) and play it in my dvd player and watch on tv, the audio volume is low at quiet parts (ie. when characters are just speaking) and the audio is normal, loudness-wise, when say there are loud sounds such as explosions and street noise. I thought it may be TMPGEnc's audio encoding, since some sites have said it isn't for audio encoding, so I tried the tooLAME and used it as an external tool. But when using the tooLAME the mpg that came out wouldn't play. I would be able to scan to scenes/parts of the movie but it wouldn't play. I have tried converting the avi audio to a separate file and encode differently, but still got the same thing, the audio volume fluctuated.
    Now, would this be a problem with my dvd player? or how I encoded it? or is it supposed to be like this? Again, when I play it on my computer it seems fine, although when I seek to another part of the movie the audio gets out of sync with the video, but when I burn it to disc it seems to play fine with the audio in sync with the video, just the audio volume fluctuates, but it plays fine on my computer though, so what's up with that?
    Can anyone help?
    Also, an aside question, the SVCD template for TMPCEnc, has 1:1 VGA as the source aspect ratio under that Advanced tab settings. I find that with this I get a "stretched" look vertically, in other words the vertical resolution is wrong I think, so I set it to 16:9 525 lines NTSC. My question is if I keep it at 1:1, will my dvd player stretch it out horizontally when I burn it to disc, even though it plays "squished" on my computer? And would this be why I'm getting the audio problems? The original avi file looks to be widescreen by the way.
    I'll explain what I did:
    I'm trying to convert Rush Hour 2, an avi file in widescreen 576x240 resolution with the audio at 48KHz 2 channels. I've converted it to mpg with just TMPCEnc, and with tooLAME, as well as converting the audio to a wav file. There are the 3 coasters. I thought it was the frequency, so I tried another movie. Shanghai Noon, with 44KHz audio frequency. I got the same audio problem, the volume was too quiet at "quiet dialogue" scenes. This is coaster #4. Note the audio playback on my computer is perfectly fine, no volume fluctuations, but only after I burn it to disc and play it in my dvd player and watch it on TV does the audio sound fluctuate.
    So, could some help me out and tell me what I'm doing wrong or advise me on what to do that might help? I'm new to this.
    Thanks for the help in advanced and sorry for the really long post.
  2. ^ TTT ^
    Anyone? Please.
    Dec 2001
    New York
    1:1 VGA, I believe just takes the source AR and uses it as the output AR, although I could be totally wrong. Tv AR is 4:3, widescreen I believe is 16:9. Seeing that you have an avi file with that resolution, I'm assuming you downloaded this flick as opposed to ripping it. In that case it could just be a bad rip from the start, do a search on GIGO........
    Sorry I couldn't be of more help....
    Wraith
    Blow me for faster replies.......
  4. the audio problem you speak of is that the audio is not comming out instereo, either it was encoded or burned wrong. make sure your burning in stereo. also check if the same thing is happening on your computer with the original avi.
