I am learning to use Adobe Encore and when I try and import an AVI file (encoded with DiVX and resolution of 640 x 480) it tell me I need a video file with 720 x 480, 720 x 486, or 704 x 480. Can I reencode this downloaded AVI file to the resolution that Encore wants? Or should I use another authoring program? I use TMPGEnc Author for very basic menus but like what Encore lets me create. Thanks for any help.
You cannot author Divx files with re-encoding them anyway. Encore has a transcoder, but I don't know how flexible it is. If it is just an mpeg transcoder then you need to have the correct format for your source material to begin with. If it can convert other formats, then you need to read your manual to work out how. If you look at What is DVD (top left corner of this page) you will see the compliant resolutions for DVD.
My preference is always to prepare assets before authoring, which means encoding them as compliant in a seperate encoder. There are many that can do this, as well as other tools to help you resize and filter your source along the way. Virtualdub and avisynth are indispensible in this respect. Simplest solution would be to use either tmpgenc plus to encode, or if you just want it done without worrying about all the complex settings, use ConvertXtoDVD to do the encoding, then use the material it has created in another authoring program. This may mean demuxing the assets from ConvertXtoDVD first so Encore can read them.Read my blog here.
Use Virtualdub's re-size filter.
He's a liar and a murderer, and I say that with all due respect.
Can't change subtitle size on avi file
By jlulu1979 in forum MacReplies: 0Last Post: 11th Aug 2011, 19:41 -
Change resolution from 235:1 to 16:9
By ThaiJan in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 15:16 -
Change audio volume in AVI file
By cheerful in forum Newbie / General discussionsReplies: 8Last Post: 15th Dec 2007, 10:12 -
How to change the audio of a movie (.avi file)!!!!
By guitarparth in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2007, 22:03 -
Change/Set aspect ratio in AVI file
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 7th May 2007, 18:28
