S-Video is better than Composite, that is the norm.
But what about RF signal ?
I have a decoder that has RF connector instead of S-Video.
Will this be less better than S-Video ?
Best to worse analog connections
YPbPr component (red green blue)
S-Video Y/C
Composite
RF (the worse unless it is the direct feed from the dish, antenna or cable to the primary tuner)
If it is the Ch 3 or 4 stuff, it is the worse quality because it is generated in a $2 RF encoder.
Low end RF still has uses for moving video with audio around the house over long (>100 ft) distances. Baseband composite video suffers more losses as cable lengths increase. High impedance consumer audio over long distance is a larger problem unless you first convert to low impedance 600 ohm balanced connections. This gets expensive.
DVP3100V - composite/SCART signal correction
By Annihlator in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Dec 2010, 05:56 -
How to Split NTSC Composite Video signal ?
By SingSing in forum RestorationReplies: 16Last Post: 26th Jan 2009, 11:50 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19 -
PixelView PlayTVpro: Composite video signal not captured
By faisalshafait in forum Capturing and VCRReplies: 0Last Post: 1st Nov 2007, 15:42
