Hi,
Please advise what I should do to add an already existing menu (VTS_01_0.VOB) to a DVD movie that is on my HD. If there is a guide I would appreciate the reference.
Thank you!
You might well be able to do what you want using a freeware tool, PgcEdit. However, this route will probably frustrate the heck out of you if you are a newbie.
PgcEdit is a very good program but it takes a lot of study to be able to use it well. In addition to learning the program itself, you need some knowledge of programming, and of how the various types of files on a DVD function. Sorry I can’t suggest something quick and easy. I don’t know of any guides here on how to do what you want. -
Titlewriter.https://www.videohelp.com/tools?tool=TitleWriter :
I have never used it but i says it will do what you want...Add Original or Generic Menus to Dvd CompiliationsSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Best way to add pop-up chapter menu?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2011, 01:08 -
add menu without re-encoding
By mathmax in forum DVD RippingReplies: 2Last Post: 9th Jul 2010, 11:40 -
How to add new subtitle option in menu
By diamondback in forum SubtitleReplies: 2Last Post: 3rd Jun 2010, 06:14 -
Keep original DVD menu, add new movie file
By Booklet in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2009, 17:21 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29
