I have a PAL avi video file (364 x 284, 25 fps, 44,100 Hz) which I want to convert to a DVD compliant format in CCE, i.e. 720x480, 29.97 fps, 48,000 Hz, using the avisynth script below, and what happens is the audio stream plays too fast. Can anyone help?
avisource("D:\My Movies\test clip.avi")
BicubicResize(720,480)
AssumeFPS(29.97)
The audio plays too fast because you speeded it up by changing the framerate.
Convert it to 720 x 480 as 25 fps, use DGpulldown to add pulldown flags for 29.970 fps playback. Demux the audio and convert to AC3 with ffmpeggui WITHOUT changing the length/speed. Author and test. Everything should play back correctly.Read my blog here.
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
CCE Pal to Ntsc conversion-NO AUDIO
By ranosb in forum Video ConversionReplies: 9Last Post: 2nd May 2009, 05:45 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
25fps AVI > NTSC DVD - am I doing this right? (AviSynth, CCE, DGPulldown
By fischkopf in forum Video ConversionReplies: 25Last Post: 22nd May 2008, 19:31
