i have 6 music dvd's all are on my backup Harddrive.
The movies are in vob format
i want to take the best chapters form each and still have them in vob format?
what can i use to do this
Results 1 to 10 of 10
ok iam in rerauthor mode and all i see is, the
menues
mail movie 1,
main movie 1 (angle2)
main movie 1 (angle3)
and then extras
in main movie 1 is 19 chapters how do i get to them -
This should help - https://www.videohelp.com/forum/userguides/198813.php
He's a liar and a murderer, and I say that with all due respect. -
thanks will try it now
looking good, this is my first time useing dvd shrink, always used nreo redord -
thanks works well but one more problem
i have 6 files now all in diffrent folders
how can i rename them so i can put them in one folder
i tryed just renaming one and it would not play
i also tryed to rename to meg put lost audio (5.1 and DTS)
eg
VTS_01_1.vob
VIDEO_TS.IFO
VTS_01_0.IFO
VTS_01_1.vob
VIDEO_TS.IFO
VTS_01_0.IFO
VTS_01_1.vob
VIDEO_TS.IFO
VTS_01_0.IFO
VTS_01_1.vob
VIDEO_TS.IFO
VTS_01_0.IFO
VTS_01_1.vob
VIDEO_TS.IFO
VTS_01_0.IFO -
thast waht i did and work good for that movie but as you see i want to do thi swith 4 movies and take 6 chapters each
i want to combine 6x4 = 24 chapters in one folder... -
If you open Shink load the first of the new movies you have created, you can drag the part you want across to the left, you can then load another movie into shrink, and it will remember the first part. You can then drag the second part across to join it. Repeat, opening all the chapters you need until you have it all compiled. Then hit backup
Read my blog here.
Removing chapters from BDMV format
By thepreacher in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Feb 2012, 10:16 -
How do i have 1 title and 3 chapters using the vob files that i have?
By Stupidboy123 in forum Authoring (DVD)Replies: 3Last Post: 18th Mar 2010, 13:00 -
DV to a format that play in QuickTime and standaloneDVDplayer with chapters
By DavidCasillas in forum MacReplies: 3Last Post: 20th Sep 2008, 21:28 -
How can I extract chapters from VOB file?
By SubFlow in forum EditingReplies: 1Last Post: 18th Jun 2008, 03:49 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 08:52
