Hello fellas. It easy to rip a dvd to any other format when you want only the movie itself.
But how about chapters, interactive menus, and other stuff?
I know .mkv is a good container. I heard that it can include chapters and attachments.
I use mkv with x264 video and ogg audio.
But I have some baby DVD's with many interactive menus, and such.
Is there a way to rip a DVD including interactive menus, and chapters, etc and store it in a single file (like .mkv) ?
If not , what would be the best way to get the result as close to DVD as possible?
Thank you.
Arguing with an idiot, make sure he isn't doing the same
I remember seeing stuff about ratDVD but i never used it so i don't know if it will compress to a single file or if you could use it to compress the dvd then make an ISO afterwards and play it with something like VLC media player.
But ratDVD retains everything on the dvd when it's compressed, menu's ect. -
You have a couple of options, however most are limited to PC or perhaps media centre playback.
.Divx allows for most of what you are after. Divx Ultra certified players should be able to play it back, but they are still thin on the ground. DivxMediaBuilder can put it all together.
RatDVD can compress a DVD and keep pretty much everything intact. Might be worth a look.
MicroDVD is another attempt to use the higher compression of Divx/Xvid and the features of DVD. http://www.tiasoft.de/mdvdp/ for moreRead my blog here.
What ever happened to ON2 ?
Loardsmurf I can't believe you said ON2. A couple of years ago the company I was working for was testing with ON2 and they at the time had better video and audio then Divix and MS.
On that topic of ON2 and this topic Flash 8 supports ON2 which is a very good encoder. In Flash you can also put in cue marks and if you’re savvy enough have the player jump to the cues. You would need to connect your PC to your TV if you want to enjoy videos from your arm chair.
ON2 is still kicking and the encoder still looks very good.
Ray -
H264+AC3 (MKV container) to H264+MP3 (MKV container)
By diebri in forum Video ConversionReplies: 3Last Post: 19th Oct 2011, 07:19 -
Incorporate a light weight browser in an LG BD-390
By wschomburg in forum Video Streaming DownloadingReplies: 1Last Post: 12th Dec 2010, 22:17 -
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 22:23 -
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 01:20 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 19:19
