Still getting audio sync problems when capturing transport streams and encoding them XViD.
Using a Fusion RT HDTV card (previously had a MyHD MDP-100) and HDTV2MPEG2 to edit out the commercials with and AutoGK to finish the project. Some XViD files are fine, others can be out of sync by 1/2 to a full second.
Not sure exactly what the problem is, ive tried various different methods. The most recent one being to encode the .TS file to MPEG2 and edit it using VideoRedo. The exported MPEG2 file becomes even more out of sync than using HDTV2MPEG2.
Is it the cut points? I know you have to insert the cut points before you go out to commercial and after you come back. Should it be a full second or can it be done at the exact frame?
Has anyone experienced this problem before and was able to resolve it? The software im using is all up to date, this is being processed on a fresh install of Win2k using only the basic setup (SP4, minimum critical updates, IE6.1, Dot Net Framework 1.1, Defiler Pak and media player classic).
Could it be the media player? Im not playing it back from begining to end, just jumping to towards the end of a clip in Media Player Classic and in XBMC.
elister - Do you live in the USA? Do you get HD through a cable box? If the answer to both is yes, take a look at:
http://hdjunkie.com/tutorials.html
for a way to record directly from a cable box to a PC via a firewire cable. Doing this vastly improved the quality of my captures and reduced my problems with dropped frames significantly.
VideoReDo can intelligently deal with sync problems, but you have to go into the settings box and tweak some stuff where you tell it repeat a frame or add silence to deal with dropped frames. VideoReDo was the ONLY application I used with HD TS captures that kept the audio in sync. I had problems with everything else I tried, which is why I bought VideoReDo. Even my much loved MPEGVCR had sync issues with HD captures. -
Wholy crap man, that worked!!!Originally Posted by jman98
In the Stream Parameters, I selected 'Detect Resync Missing Frames' and changed it to 'Resync - Insert Extra Frames' and it appears to be working fine now.
Thank you very very much!!!!
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
