Hi,
I have tried to merge 4 DVDs using dvdremake pro. I did all the steps as described in the dimasoft.com web site as well as described in this site. The result is a DVD with the dvdremake main menu, but I don't see any links, so I can't get to any of the original DVD menus. When I run the debug mode in DVDremake it looks fine but after exporting the merged DVD the main menu simply doesn't work (tried it in a few PC DVD players and on a standard DVD player).
Did anybody have this problem? Any solution?
Thanks.
I'm pretty sure there's forums at Dimad's website, which might be a more suitable spot for your question.
Personally I've only ever merged 2 DVDs at a time, and it has worked great every time. Although I must say that I change the default menu to a more customised one.If in doubt, Google it. -
Copies of DvdReMake Pro downloaded from Dimadsoft.com work correctly: http://cdr-zone.com/forum/viewtopic.php?t=1393
Alright then, does anybody know a way to merge the DVDs with the original menus with a different software?Originally Posted by dimad
It's very hard, bordering on the impossible, unless you're very knowledgeable:
http://forum.doom9.org/showthread.php?p=684600#post684600
Complete thread begins here:
http://forum.doom9.org/showthread.php?t=96211
Fargo frame shows up when played but not inside DvdRemake
By c627627 in forum Authoring (DVD)Replies: 6Last Post: 25th Jun 2010, 17:07 -
Highlight buttons in DvdReMake Pro menu
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 25th Apr 2010, 18:21 -
DVDremake Pro button problem
By Yaro in forum EditingReplies: 2Last Post: 16th Aug 2009, 16:54 -
DVDRemake don't work?????????
By bens dad in forum Newbie / General discussionsReplies: 7Last Post: 4th Jan 2008, 12:18 -
DVDRemake Backup folder is not Playble
By src2206 in forum DVD RippingReplies: 2Last Post: 2nd Dec 2007, 13:03
