Hey everyone, I cant seem to figure out why after encoding a DVD to AVI using this guide http://www.rita.lt/guides/GKnot_DVDtoAVI.htm I get a green screen?? The sound works fine but I have no video. Right now I am using DivX 6 codec, Could that be the problem?
Any help is much appreciated, please I am a newb at this so if you need any specifications of the file information when encoding please dont hesitate to ask and I will retrieve it for you. In the mean time I will try switching to Divx 5 codec and see what happens.
Did you encode to XviD? I think you may have FFDSHOW installed and it's causing the problem. You're better off using the native XviD codec.
Which player are you using? Try opening a DivX file with Media Player Classic. While the video is playing, right-click and hover the cursor over "filters". Post which video decoder is being used. I wonder if it's even DivX. Which version of DivX do you have installed?
My guess is that this is a playback problem, not a problem with the encoding. Most likely a codec conflict. Try playing the DivX in VLC
/Mats
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 22:31 -
Green Screen Advice
By HoosierGuy in forum Newbie / General discussionsReplies: 19Last Post: 8th Mar 2011, 08:53 -
How to use green screen with video?
By MitchStevens in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jun 2009, 19:33 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 19:35 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 00:16
