    Aug 2006
    Estonia
    I want to make a dvd with to titles: main movie and extra. They both need to have subtitles.
    https://www.videohelp.com/%7EGFD/1FilmAndSubmenus.html <- follwed that guide and i got everything done except, i don't know how to set subtitle for extra movie. For main movie i used:
    if (g1 eq 0) {subtitle=64;resume;} else {subtitle=64;jump menu 1;}
    When i used
    if (g1 eq 0) {subtitle=64;resume;} else {subtitle=64;jump titleset 2 menu;}
    for extra, then GuiAuthor.log ended with following error message:
    ERR:  Cannot jump to title #2, only 1 exist
    ERR:  in VTSM pgc 0, button TS2B1
    TitleSet2 Button1 action is set to
    Thank you
    edit
    Just in case here is my dvdauthor.xml file
    <?xml version="1.0" encoding="utf-8"?>
    <dvdauthor dest="d:\MyProject\DVD">
    <vmgm>
        <menus>
        <video format="pal"></video>
          <pgc entry="title">
           <pre> { if (g1 eq 0) g1=1; button=g1*1024; } </pre>
            <vob file="d:\MyProject\Temp\MMMenu.mpg" pause="inf"/>
            <button name="MMB1">jump titleset 1 menu;</button>
            <button name="MMB2">jump titleset 2 menu;</button>
          </pgc>
        </menus>
    </vmgm>
    <titleset>
        <menus>
          <pgc entry="root">
            <pre> { subtitle=64; button=1024; } </pre>
            <vob file="d:\MyProject\Temp\TS1Menu.mpg" pause="inf"/>
            <button name="TS1B1">jump menu 3;</button>
            <button name="TS1B2">jump menu 2;</button>
            <button name="TS1B3">jump title 1 chapter 1;</button>
            <button name="TS1B0">jump vmgm menu;</button>
          </pgc>
          <pgc entry="Subtitle">
            <vob file="d:\MyProject\Temp\SM1Menu.mpg" pause="inf"/>
            <button name="SM1B1">if (g1 eq 0) {subtitle=64;resume;} else {subtitle=64;jump menu 1;}</button>
            <button name="SM1B2">if (g1 eq 0) {subtitle=65;resume;} else {subtitle=65;jump menu 1;}</button>
            <button name="SM1B3">if (g1 eq 0) {subtitle=66;resume;} else {subtitle=66;jump menu 1;}</button>
            <button name="SM1B4">if (g1 eq 0) {subtitle=0;resume;} else {subtitle=0;jump menu 1;}</button>
            <button name="SM1B0">jump titleset 1 menu;</button>
          </pgc>
          <pgc>
            <vob file="d:\MyProject\Temp\SM2Menu.mpg" pause="inf"/>
            <button name="SM2B1">if (g1 eq 0) {audio=0;resume;} else {audio=0;jump menu 1;}</button>
            <button name="SM2B2">if (g1 eq 0) {audio=1;resume;} else {audio=1;jump menu 1;}</button>
            <button name="SM2B3">if (g1 eq 0) {audio=2;resume;} else {audio=2;jump menu 1;}</button>
            <button name="SM2B0">jump titleset 1 menu;</button>
          </pgc>
        </menus>
        <titles>
          <audio lang="EN" />
          <audio lang="EN" />
          <audio lang="EN" />
          <subpicture lang="ET" />
          <subpicture lang="EN" />
          <pgc>
           <pre> { g1=0; } </pre>
            <vob file="d:\MyProject\Temp\VTS_01_PGC_01_1 - 0xE0 - Video - MPEG-2 - 720x576 (PAL) - 16~9 - Letterboxed_SUB3.mpg" chapters="00:00:00.000,00:05:50.000,00:05:59.000,00:08:06.000,00:15:43.000,00:19:00.000,00:22:45.000,00:27:21.000,00:33:12.000,00:36:37.000,00:40:31.000,00:43:38.000,00:54:20.000,00:58:44.000,01:05:44.000,01:07:59.000,01:10:28.000,01:15:11.000,01:22:24.000,01:26:59.000,01:30:01.000"/>
            <post>call vmgm menu 1;</post>
          </pgc>
        </titles>
      </titleset>
    <titleset>
        <menus>
          <pgc entry="root">
            <pre> { button=1024; } </pre>
            <vob file="d:\MyProject\Temp\TS2Menu.mpg" pause="inf"/>
            <button name="TS2B1">jump title 2 chapter 1;</button>
            <button name="TS2B2">if (g1 eq 0) {subtitle=64;resume;} else {subtitle=64;jump titleset 2 menu;}</button>
            <button name="TS2B3">if (g1 eq 0) {subtitle=65;resume;} else {subtitle=65;jump titleset 2 menu;}</button>
            <button name="TS2B4">if (g1 eq 0) {subtitle=0;resume;} else {subtitle=0;jump titleset 2 menu;}</button>
            <button name="TS2B5">if (g1 eq 0) {audio=0;resume;} else {audio=0;jump titleset 2 menu;}</button>
            <button name="TS2B6">if (g1 eq 0) {audio=1;resume;} else {audio=1;jump titleset 2 menu;}</button>
            <button name="TS2B0">jump vmgm menu;</button>
          </pgc>
        </menus>
        <titles>
          <audio lang="EN" />
          <audio lang="EN" />
          <pgc>
            <vob file="d:\MyProject\Temp\extra_SUB2.mpg" chapters="00:00:00.000"/>
          </pgc>
        </titles>
      </titleset>
    </dvdauthor>
    Aug 2006
    Estonia
    anyone?
  3. Sorry for answering a little late, but I have been in holidays the last two weeks.
    Within each titleset the actual movie is always 'title 1'. Therefore the button should have the action:
    <button name="TS2B1">jump title 1 chapter 1;</button>
    Quite the same applies to the subtitle selection buttons:
    These buttons should be created the same way as in the titleset1. You can create another subtitles menu and audio menu within the titleset 2 menu (same procedure as for 'Main movie' = titleset1) or use 'combined actions' for the buttons directly on the TitleSet2Menu (if only some combinations of audio/subtitle are required):
    <button name="TS2B1">subtitle=64;audio=0;jump title 1 chapter 1;</button>
    <button name="TS2B2">subtitle=0;audio=1;jump title 1 chapter 1;</button>
