I'm currently editing with AVID XPress Pro for the Mac.
All of my projects are 23.976.
NOW, I'm wanting to dub these off to Mini-DV or DVCPro NTSC. The way I'm currently down converting is taking the MOV's into After Effects.
Here are my After Effects settings: Comp is 23.976, my export settings are 29.97 with 3:2 pull down at WWWSS.
AVID imports them at lower fields first.
Now I've noticed in AVID when I import, that sometimes there are waves between cuts (like the end of the first cut is lower fields and the start of the next cut is the upper field...as if the cut was at the SS or WS) and waves betweens fast brightness (e.g. when turning the lights on and off to simulate lightning).
What do I need to export my projects at to format them to NTSC 30i for broadbast?
Results 1 to 1 of 1
24p source to 24p DVD - am I doing it right?
By Killer3737 in forum Video ConversionReplies: 30Last Post: 14th Oct 2011, 18:40 -
FFmpeg - 60p to 30i
By bunklung in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 19:57 -
converting from 30i to 30p with Virtualdub; before or after cutting?
By CFPJer in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 23:17 -
24p -> pal -> ntsc back to 24p
By StrobeLightEpileptic in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 00:56 -
30i and 30 fps mjpeg in same project
By SCDVD in forum EditingReplies: 4Last Post: 8th Sep 2008, 23:37
