The audio source I am converting from is 129kbps but TMPGEnc won't let me lower the audio settings. It is locked at 240kbps. How do I change it?
You have to load the "unlock" template which is in the extras folder in addition to the SVCD or VCD template. This will allow you to change the audio bitrate.
Okay, thanks for the information. I have another question. When I select the toolame audio encoder with TMPGEnc I have a problem. After TMPGEnc does something called "creating Temporal wave" the entire applications bombs out and never continues the conversion. What is causing that? I don't get an error or anything, TMPGEnc just shuts down.
Reencoding VC-1 WMV at lower bitrate
By casimps1 in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 23:34 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 01:43 -
4+hour DVD9, lower audio bitrate for better video?
By sdsumike619 in forum AudioReplies: 10Last Post: 24th Oct 2007, 12:24 -
Bitrate always comes out lower?
By MrMors in forum Video ConversionReplies: 6Last Post: 1st Jun 2007, 08:37
