My 30 day trial of TMPGEnc is OVER, and TMPGEnc will NO LONGER MUX m2v and mp2.
Can someone please recommend a freeware program that WILL mux m2v & mp2?
Again, please don't recommend TMPGEnc, it doesn't mux m2v & mp2 after the 30 day trial period.
TIA.
Peace.
				Results 1 to 13 of 13
	mplex from mpegtools (found in DVDAuthorGUI among other packages IIRC)
 /Mats
	no, mplex is from mJpegtools...
 bbmpeg has also a builtin multiplexer tool.
	Thanks.Originally Posted by Baldrick
 I noticed mJpegtools is designed for the Linux OS.
 I should have stated earlier that I am using Windows XP Professional.
 TIA.
 Peace.
	Get the DVDAuthorGUI package. In that, you'll find mplex for Windows. A Google for "mplex windows" will also give you some leads...
 /Mats
	Actually, for me, YES.Originally Posted by Baldrick
 I tried ImagoMPEG-Muxer and it produced an mpeg-2 that VCDEasy rejected w/ an error message,
 "Error - "movie.mpg" analyse failed:"
 Although the mpg plays fine in WMP, Gspot sees a really strange mpeg2 file (which is probably why VCDEasy rejects it).
 I have no idea why ImagoMPEG-Muxer is NOT producing an mpeg-2 file that works w/ VCDEasy.
 Before the 30 trial ran out, TMPGEnc muxed the m2v and mp2 to mpg, and VCDEasy accepted the mpeg-2 file w/o an error message.
 BTW, the mpeg2 file is SVCD compliant (480x480 NTSC), w/ a 3:2 pulldown from 23.97 to 29.97.
 I guess I'll try mplex later, unless someone can tell me how to resolve the problem w/ ImagoMPEG-Muxer and VCDEasy.
 I would prefer to use ImagoMPEG-Muxer, because I'd rather have a GUI.
 TIA.
 Peace.
	bbMpeg will produce multiplexed files that are accepted by VCDEasy ... At least I never had any problems with that combination when I was still creating PAL SVCD's (about 5 years ago, so I don't have any idea of the current VCDEasy version).Originally Posted by 2397to2997
 BTW, bbmpeg has GUI.
	I tried bbMPEG, the 1st mux was a success, VCDEasy accepted the mpeg-2 file.
 The 2nd mux was NOT a success. bbMPEG gave the following error message: bbMPEG gave the following error message:
 Multiplexing file temp.mpg
 video PTS (1365243.70ms) underflow at pack 130056 by 92.43ms
 1 video underflows (SCR >= PTS or DTS)
 NOTE: The resulting file may not play back correctly.
 Try increasing the mux rate.
 Finished multiplexing temp.mpg
 End of error message.
 What must I do to "increase the mux rate"???
 There's alot more setting to worry about in bbMPEG than TMPGEnc, so I need to RTFM.
 Thanks everyone for you help! I hope you can help me solve the latest problem posted above.
 TIA.
 Peace.
	The DVDAuthorGUI program doesn't allow me to mux a DTS audio track into my project (it can only find AC3, MP2, MPA, M2A). However, the mplex command-line tool allows me to mux a DTS track into a generic MPEG2 file. Why doesn't the GUI accept DTS whereas mplex does? The GUI invokes mplex during the process, am I right?
  How to mux M2V and MP2 ?By aussie74 in forum Authoring (DVD)Replies: 5Last Post: 19th Mar 2012, 08:17
  Convert/Mux .m2v and .wav into mpeg for DVD??By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 15:46
  How to mux a m2v file with 44.1khz, 16-bit wav?By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 23:25
  Converting MOV to MP2 mux errorBy Compufix in forum ffmpegX general discussionReplies: 2Last Post: 30th Nov 2010, 01:38
  Re-mux m2v aiff to vob freewareBy MaiOns in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2010, 03:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
