I have a music file that is 1.74gb I would like to put the tracks on cd's to play on stand alone players. Is there a programme that will compress![]()
the tracks to fit as many on a single disk as possible that will also play on a player. Any advice I would be greatful.
CD audio is uncompressed PCM at 16bit 44.1 kHz. You are fixed on how much you can fit. It is not like DVD, where you can just reduce the bitrate.
If you want to play it in MP3 capable players, then you can start to squeeze it down some. But if you want it playable as a redbook standard audio CD, you will be restricted to around 74 minutes on a standard CD.Read my blog here.
Syncing segments of video with audio differently (stretching, compressing)
By Kreachure in forum EditingReplies: 2Last Post: 5th Mar 2012, 11:27 -
Loss of audio sync when compressing or converting DV files on Mac
By Sloperman in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2011, 09:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Compressing Audio
By Bacender in forum Newbie / General discussionsReplies: 4Last Post: 15th Jan 2009, 01:46
