I am using Convertx2dvd to convert episodes and burn them to a Dvd. I alway get some audio out-of-sync with at least one or two of the episodes per dvd. They play great when watched on my pc but once I convert them and burn them I have the problem....Is there a better program out there that can convert numerous avi's so they can be burned onto a dvd? Thanks.
There are better tools, but not another all-in-one converter I can think of at the moment that is as easy as ConvertXToDVD for what you are doing and does a fair job of conversion.
The better way is to use the individual tools like standalone encoders and authoring programs. TMPGEnc encoder and TDA are two I use. TDA doesn't do subtitles, though, if you need them.
ConvertXToDVD doesn't usually have sync problems. What format was the audio in before conversion? If the videos had MP3 VBR audio, that might explain the problem. Most encoders have problems with it. The other possibility may be a corrupted video or audio in the original files. This doesn't always show up in a software player. If you still have one of the problem (AVIs, I'm guessing) videos drop it into VirtualDub or VD Mod and check for bad frames or VBR.
If you have none of these problems, then try some different programs. If you look to the left in 'Tools' you will see some other converters, along with encoders and authoring programs.
convertx2dvd video bitrate can we fix?
By sumeshkri in forum Video ConversionReplies: 4Last Post: 11th Jun 2010, 16:50 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 02:29 -
ConvertX2DVD - menu issue
By urmum in forum Video ConversionReplies: 3Last Post: 31st Jan 2008, 06:59 -
ConvertX2DVD shutdown
By smalld in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 20:27 -
What version of Convertx2dvd to use?
By aat666 in forum Video ConversionReplies: 8Last Post: 26th May 2007, 00:08
