FLV Extract seems like a nice tool to split FLV files. I'd been previously using SUPER to convert them to some sort of non-DVD complient mpeg, then sending it thru TMPGEnc (too cumbersome). But FLV Extract extracts to an .avi and a mp3. Here's what the documentation says:
is there anyway I can get TMPGEnc Plus to use the right decoder to convert these files? I installed ffdshow and I run MPC, but don't know too much how TMPGEnc environmental 'VFAPI plug-in' section really works. I bumped up 'AVI VFW Compatibility Reader' without any success..Extracts video and audio from FLV files without decompressing or recompressing. The video is saved to AVI (H.263/FLV1 and VP6/FLV4 are supported) and the audio is saved to MP3.
NOTE: The AVIs will not play unless you have the right decoders. ffdshow contains a decoder for FLV1 and Media Player Classic contains a decoder for FLV4.
				Results 1 to 21 of 21
	Yep, flv splitter (added to the tools list now), ffdshow with flv1 enabled and avisynth works fine here. I can also open most flvs directly in tmpgenc (directshow reader priority +1).
 but how about the new flvs with vp6/7 ?
	I read at another forum that you could it with Gabest's VP6 DirectShow decoder.
 i havent tried it and i also couldnt find any link to downloaded it.I love it when a plan comes together!
	Tmpgenc mpeg1 encoded clip: zidane.mpg
 Maybe http://www.free-codecs.com/download/VP7.htm or http://www.free-codecs.com/download/VP6.htm ?
 edit: Nope, just audio and no video...
	Found an updated FLV splitter, http://ffdshow.faireal.net/mirror/Media%20Player%20Classic/external%20filters/unicode/FLVSplitter.7z
 and I can now open flv4 after using flv extract in TMPGEnc!
 so for both flv1 and flv4
 1. Install ffdshow, enable FLV1
 2. Install flv splitter ( Start->Run regsvr32 c:\location\flvsplitter.ax )
 3. FLV Extract to avi and mp3
 4. Open avi and mp3 in tmpgenc
 but how is the flv4 video decoded? has the newer flvsplitter a builtin vp decoder also?
	I managed to get things working on my end too. Turns out I had the FLV Splitter installed twice. All I had to do was remove one.
	Yeah, I was about to say that my splitter had VP62 decoding enabled. Gabest left it disabled to avoid legal troubles. The decoder isn't even in the svn. Still the offical splitter should still work if you have On2's decoder installed. Just probably with upside down video.
 Shouldn't be any need to extract flv's either. TMPGEnc should be able to open them directly.
	Somebody can explain about this please?Originally Posted by Baldrick
 horay... i can open flv with Windows Media Player and TMPGEnc
 Thanks everyone
	To extract an FLV file in TMPGenc 2.58 or 2.59 (I use)
 1. install fdshow and under video filters set FLV1 to libracodec
 set VP62 to livracodec
 2. install Gabest flvsplitter.ax to windows in system32 directory and right click to register it
 3. place the FLV Input filter from VirtualDub.org in TMPG install directory and rename the file
 ending to *.vfp
 and it works for me
  FLV Extract Cropping ErrorBy TAS257 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2012, 21:55
  which software works best for flv to dvd can i convert dvdor flv to divxBy rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39
  TmpgEnc Express can't open flvBy pcb in forum Video ConversionReplies: 9Last Post: 1st Aug 2010, 16:45
  Extract audio from FLV (on Mac)By matt276 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2009, 13:26
  Extract a frame from .flv file using .Net programBy evolvingwheel in forum EditingReplies: 0Last Post: 18th Jan 2009, 10:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
