    Aug 2006
    Austria
    Hi, me newbie into all that stuff, i did use the forum search, but couldn't find a topic about this:
    A friend of mine knows less about this stuff than i, but managed to rip off a relevant part (he doesn't remember how), from a DVD which seems to be authored ok.
    The file plays fine in every Viewer, but i cant sort of "touch" it to author it again.
    Nero, DVDShrink, tmpgenc... all state or complain that this is not a valid DVD-file or even don't show it when browsing (no filter, *.*)
    With this Vobfile i received also a dv2, idx, lst, bup, ifo -file.
    I tried with several tools, but now i am somehow blockheaded, i just don't get it.
    Getting this thing to burn would be enough, although i originally wanted to recode it to whatever to reduce the size massively as quality doesn't matter.
    Thanks for some hints
    chris
    could you list all files?
    Aug 2006
    Austria
    sorry, what do You mean with list files?
    just to get sure... :
    sdive.d2v
    sdive.idx
    sdive.lst
    sdive_0 (as stated by win, "Type: bup file")
    sdive_0 (... ifo file)
    sdive_001 (text document)
    sdive_1 (playable vob file)
    sdive_info (text document)
    thx, chris
    tried import the vob file with tmpgenc dvd author ?
    or try demultiplex to video and audio files with tmpgenc->mpeg tools->demultiplex and import them in the authoring tool like tda.
    or try open in videoredo and save as a mpg file.
    Aug 2006
    Austria
    Hi Baldrick,
    Standing in a forest of tools, Your post got me on the way back to logic thinking!
    I managed to create a mpeg stream with video-redo and demux the stream with tmpgenc mpegtools.
    That helped a lot, as i didn't even know what is demux, remux etc... so i enjoined myself somekind of private lessons on DVD-Backgrounds
    Glad i also got rid of a turorial-audiostream, authoring with freshly purchased TDA - a great app.
    Thanks very much for Your suggestions!
    chris
