  1. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Apparently, researchers were studying the T-Cells of AIDS patients to see why they slowly stopped fighting the HIV virus. They discovered that T-Cells have a sort of "switch" on them, turning them on or off ... and the HIV virus has discovered how to turn them off with their own switch referred to as PD-1. Anyhoo, these researchers (in South Africa) discovered how to disable the PD-1 switch in HIV ... and that when done, the T-Cells reinvigorated themselves.
    In short, they didn't find a "cure" for HIV, but they did discover how to disable HIV's PD-1 switch - which it uses to turn off T-Cells. This is probably going to end up on page 17 of your local newspaper ... so I thought I'd let people know about it:
    http://www.infectioncontroltoday.com/hotnews/68h21949306774.html
    Hope springs eternal. Hmm ... here's a thought. A while back, I heard one physician comment that a "cure" for AIDS would be a mixed blessing. While AIDS has raised an awareness to safe-sex practices, it has also taken attention away from other STDs - some of which can be just as bad. He worried that, if AIDS was cured, people would abandon safe-sex practices altogether ... and we might end up seeing a pandemic of syphillis (where you get infected in 2006 - and wake up blind in 2020, with no real warning signs beforehand).
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Hi,
    I would prefer a curable epidemic though. Most STDs can be cured very cheap, HIV is the most expensive and painful slow death man can imagine, I have visited forums full of people telling their own stories and horrors, and believe me: I hope I never get HIV.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Originally Posted by Abbadon
    Hi,
    Very true. There's even been research done in Australia regarding the similarity between the HIV virus and the Herpes virus ... that with a little genetic manipulation, HIV can be programmed to reproduce as Herpes. Given the choice, I'd much rather have Herpes.
    Anyhoo, with all these breakthrough discoveries coming hot and heavy, I suspect that sooner or later there WILL be a treatment for HIV. Perhaps not a cure - but at least a means to control it, like diabetes.
  4. I think I agree with Chris Rock regarding aids.
    He always says this in his specials:
    Chris Rock says: Nobody is trying really hard to cure it, because there is no money on a cure. Money is on a treatment, slowly squeezing you out of money until you are dry and then they leave you to die.
    Then he follows with a Joke:
    "Nah.. all doctors are worthless... a joke, they are all a joke. 200 Years of research and they can't even cure athlete's foot!"
    I think that instead of trying to find a cure on their own, all researchers should research TOGETHER, sharing the discoveries and spreading the knowledge among them, brainstorming... whatever it takes to do it.
    I think that there should be a global research team devoted to find the cure for aids (and even cancer)... financed by Bill and Melinda Gates
    I think that if all doctors worked together we would be seeing results in this lifetime, but I seriously doubt it because the bottomline is:
    There is no profit in that
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  5. Banned
    Aug 2006
    Spain
    it's a cruel thing... is it true indeed?
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    This kinda ties into a discussion I had once about the idea of a non profit public domain corporation.
