  1. I found the script below in the convert-section in order to convert real media to avi. I have the latest version of avisynth and also virtualdubmod installed, but I get an error message when I drag the avs file into VirtualDubMod:"No Video Stream Found". Does anyone know how to fix this problem or an alternative way to convert rm to avi or mpeg?
    DirectShowSource("C:\My Movies\....\test.rm", fps=29.97, convertfps=true)
    USA
    I have never tried VDM with RM video, not sure how that would work. You might try the freeware converter SUPER, as it lists RM conversion.
    Nov 2002
    So what happens if you open the AVS file from VDubMod, instead of drag and drop?
    Apr 2004
    Miskatonic U
    I believe you also need real alternative and perhaps even a splitter installed to allow avisynth to open the file. It appears, at present, that you don't, which is why there is no stream.
    Either install real alternative, or try SUPER or MediaCoder
    Read my blog here.
  5. I do have real alternative installed, maybe I need to update it? Anyway, in the mean time I found an easier way. I installed the 30 day trial of EO Video, which has a built in convereter for Real Media, it worked great!
    Thanks for the help though!
    Jan 2003
    India
    Sure Stream real video files, contain more than one video and/or audio streams. You need to create a new file with single audio and single video stream.The following will do this for you
    http://elwood.webz.cz/SureStreamBeta.zip
