Some help please. I have several AVI clips I want to convert to DVD. Which one of these are better? Can I use CloneDVD Mobile to convert from AVI to DVD? Just wanted some opinions, please. Thanks for any response.
use convertxtodvd. clonedvd mobile is for "dvd to" conversions.
thanks for the quick reply. Besides convertxtodvd, is there another similar program to convert avi to dvd? Thanks again.
If you want quick and simple with the best chance of a reasonable outcome, ConvertXtoDVD would be the one to use. Thereis a free version called DivxtoDVD which is also good, but not as refined as the payware one. Steer clear of WinAVI and DVD Santa.
If you want the best quality, fitCD, avisynth and a good encoder is definately the way to go. It takes a little longer to set up the first couple of times, the encoding will definately take longer, but the quality will be substantially better in most cases.Read my blog here.
Thanks all. I guess I will try convertxtodvd. guns1inger using fitcd and avisynth seems alot for me, still trying to learn about these types of recordings. Thanks for the help. Have a nce day all.
MEncoder 4 Mobile
By arpan251089 in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2010, 23:28 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 07:14 -
Should I Get T-Mobile Or O2 Contract?
By Nitro89 in forum Off topicReplies: 0Last Post: 18th Jul 2009, 15:03 -
audio from mobile
By devdev in forum AudioReplies: 1Last Post: 14th Apr 2009, 18:10 -
Need specific setting for CloneDVD Mobile.
By g12345567 in forum Portable VideoReplies: 2Last Post: 25th Mar 2008, 18:05
