Hi everyone:
My hard disk has 2 drives, C & D. I can defrag my drive D just fine, with either Windows Disk Defragmenter or Norton Speed Disk.
But I cannot defrag my drive C. Each time I tried to defrag it, I would receive a message indicating that an unknown disk utility was being run, locking the drive. The message also gave me an ID No. DEFRAG00105.
I have used anti-spyware softwares (Ad-Aware, Zero Spyware, Spy Sweeper), anti-virus software (AVG, Norton) to check on my computer. Nothing was found.
I also tried Safe Mode, and still got the same error messgae (ID DEFRAG00105).
I searched my entire computer, no such thing as DEFRAG00105 was found.
Would someone please help me?
Thanks![]()
My OS: Windows 98SE
http://support.microsoft.com/kb/286810/EN-US/
http://www.annoyances.org/exec/forum/win98/t1006071761
http://www.computing.net/windowsme/wwwboard/forum/30642.html
http://www.computing.net/windowsme/wwwboard/10.html
Check the first two posts ... at the top
Since your using Win98SE ... why not just defrag it ... in DOS ... I use to run scandisk all the time in DOS
If it doesn't respond using a startup disk ... make sure your startup disk has those commands on the floppy ... if not ... copy them from the Windows\command folder -
Thanks.
I used boot disk to scan my drive. The drive is now defragmented.
Cheers
Defrag question
By Megahurts in forum ComputerReplies: 4Last Post: 28th Dec 2010, 09:36 -
Incomplete Defrag
By bevills1 in forum ComputerReplies: 21Last Post: 9th Jan 2009, 21:57 -
Defrag Software
By lifesajrny in forum ComputerReplies: 9Last Post: 30th Jul 2008, 09:30 -
How much free space needed for a defrag
By Rudyard in forum ComputerReplies: 5Last Post: 17th Apr 2008, 15:52 -
External HDD freezes my pc and will not defrag
By TONY L in forum ComputerReplies: 13Last Post: 7th May 2007, 10:31
