Hi folks!
For Audio-CD playback, the Pio is connected to the amplifier by optical cable as well as cinch. The amp is switched to Auto-input, so it selects the PCM stream coming through the optical connection. The PCM indicator sign of the amp's display is on.
It was like this up to some two weeks ago. Since then the playback tends to get interrupted every 10 to 40 seconds or so, the PCM sign goes off - temporarily.
Any idea what's wrong there? (By switching between the amp's input terminals and trying different optical cables I could track down the source of the problem to the Pioneer.)
Thanks for any clues.
I hate to state the obvious, but it appears the optical connector or circuitry is bad/failing. Unless it is under warranty, it would most likely be more cost effective to get a new unit.
Google is your Friend
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 09:52 -
Converting videos for playback directly on Xbox 360...
By kevinmd88 in forum Video ConversionReplies: 3Last Post: 18th Aug 2011, 00:09 -
Burned DVD playback on Xbox 360?
By cmcfalls in forum DVD RippingReplies: 3Last Post: 25th Mar 2011, 15:30 -
Jerky video playback on Xbox 360 (AVStoDVD)
By KKPHM in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2010, 02:56 -
My last hope with .MP4 playback on xbox 360
By kanwar786 in forum Video ConversionReplies: 12Last Post: 18th Feb 2009, 13:05
