Hey Guys,
Anyone know how to change the "Always take this action" setting once you have set it? I had a program set up to start every time I connected my DV Camera, but now I want to disable that feature as I no longer use that software. It's very annoying for me coz I have to wait for it to fire up every time I connect only to then close it down straight away.
Have looked everywhere through my Windows settings but can't seem to find the option I need. Any help appreciated... Thanks all.
Richt-click on the camera when it's connected and go to Properties. The AutoPlay tab will let you change the option.
Another quick and dirty option would be to uninstall the application you autostart.
Thanks for the tip, but there is no AutoPlay tab in the properties menu when I right click on the camera.
I would like to learn how to fix this without uninstalling the offending program. Anyone got any other ideas?
Thanks... -
A couple of questions:Originally Posted by Raniburger
1. What is the offending app - in particular, what is its filename?
2. When you plug in the camera, do you see the little camera icon appear in the system tray in the bottom-right of the screen? If so, right-click to open the dialog box that lets you set the default behaviour.
There's a whole bunch of stuff in the registry that tells the OS what to do. Knowing the app's filename will help track down the right entries to change/delete etc.
In the meantime, you can:
1. Disable all Autoplay behaviour by stopping the "Shell Hardware Detection" service. You need to go to Control Panel/Administrative Tools/Services, click on the "Shell Hardware Detection" in the list then click the Stop button at the top of the Services dialog.
2. According to Microsoft, start the application you want to use, then connect the camera. If things behave as they should, the OS will realise you are using a different handler app and not start the offending one. Emphasis on "should"!
Please post back....John Miller -
There's more than likely a way to disable the offending program within the app itself.
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 20:04 -
First "Action Video" with Effects
By gree in forum EditingReplies: 4Last Post: 28th Apr 2011, 11:51 -
VHS-->DVD, "action scenes" and bad sources
By Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 01:09 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"Sliced" playback during pans and action scenes.
By GMaq in forum Software PlayingReplies: 9Last Post: 1st Nov 2007, 10:07
