I have a dell dimension 4550 i believe and i recently messed up the headphone jack in the front underneath the cover next to the usb jacks. It looks like it got pushed in and now its not working.
I found another jack, its on the cd drive, it has a volume control thing, but when i put my headphones......nothing.
Im using windows xp, is ther any setting i need to set it on to use the cd drive jack as the default one?
Results 1 to 19 of 19
The jack on the CD drive is only for the CD drive. I know of no way to make it usable for general computer use.
Buy My Books -
You could use the rear audio output jack, though you would have to unplug your speakers or put in a 'Y' splitter and just turn down the speakers. Or many speakers have a headphone jack on them. Unless you don't want to replace your speakers, that would be the easiest.
Replacing or repairing the front jack is likely a big project. -
Originally Posted by redwudz
The jacks themself are about $1.00 at Radioshack. -
Well on a Dell like yours the Headphone jack is on a small circuit board that mounts the jack, The Mic (sometimes) and the USB sockets.
You should be able to order the board from Dell. It is usually held in by one or two screws. I believe yours sits in the front under the HDD bays and has two ribbon cables going to it. Easy enough to change once you get the part. -
My headphone wires are not long enough to reach from the back of my comp to where i sit. Is there extensions wire out ther, and how much do they cost in general?
also, it will be a pain to go to the back of my comp everytime i wanna listen to music, are there settings on my comp that i turn the headphone jack on and off? -
It could depend on your skill/comfort level when it comes to opening up your laptop.
Personally I would open it up and at least have a peek at the mount and connection at the jack to the board. I don't know if the jack is mounted to a board or has a short section of wire to it. (Best case IMO) from there either repair what you have, replace it with an exact replacement part if you can find one or do some Micky mouse conversion.
I am by no means an electronic tech but I have made a simular repair before using the female end of a patch cord and letting it just dangle out of the case with a stopper knot tied inside of the case to keep from pulling it out. It was a two way radio base station and as far as I know it is still working.
You might be able to find a small shop that will fix it, but I bet that it will cost a hundred bucks. I have the utmost respect for some of these guys' knowledge, but damn they can seem heartless when it comes to charging you. I would pay $50 and bite the bullet, but much more I would start to squirm a little.IS IT SUPPOSED TO SMOKE LIKE THAT? -
The easier approach is still using a Y-cable or extension cable. The best approach is get a Speaker with headphone jack.
Thers a few local shops that i can ask, ill check tomorow, but for the time being im goin to get a extension cord
Originally Posted by SingSing
The Dimension 4550 is the larger tower as I recall it not a laptop?
The headphone jacks on these are usually on a easy to change bord, one screw two locator slots 3 cables, 1 for audio, 1 for USB, one for the front panel buttons andLEDs. Just call Dell and buy. Look in the case after opening looking in from the back it should be on the right side under the drive bays. -
Originally Posted by TBoneit
ROF just curious what would you charge to resolder a Audio jack in a laptop?
Some of the prices you quote are awfully low. $5 ? maybe if the customer brought it in already out of the computer, not if I have to open the case and since it is a Dell Clean out all the dust as well as r/r the part. -
My prices depend on the customer and the laptop in question. This isn't a laptop though. -
Ima start calling around now, im not that hands on and i dont want to touch anything thats been soldered.
Thanx for all the help, i wasnt expecting ppl to know about headphone jacks -
I don't know why I thought it was a laptop. Silly me. Don't get old, your mind will trip you up just for fun.
Zapper as you know there are three things that tell you that you are getting old
1. You start forgetting things
2. Um er....
Where was I?
What am I doing here?
Oh well, bye. -
I have been a broken man ever since a teenaged girl called me Sir.
I have reread the whole topic three or four times, and I would have sworn that before I posted someone mentioned laptop. Oh well, time for my medicine.IS IT SUPPOSED TO SMOKE LIKE THAT?
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 21:39 -
Stereo Out to headphone jack (3.5mm)?
By therock003 in forum AudioReplies: 34Last Post: 17th Feb 2012, 00:47 -
Any ideas on why audio through headphone jack stutters on MacBook?
By ryangarfield in forum ComputerReplies: 2Last Post: 30th Mar 2010, 22:07 -
Headphone jack extenders?
By Nintendo Fan in forum Off topicReplies: 5Last Post: 5th Jan 2010, 11:25 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 16:10
