Hi All,
I'm somewhat of a newbie to all this. I used to have a DC 30 capture card that I was using for transferring VHS to DVD R. I Was running Win 2K and it was hard to get the DC 30 working right at first but when I did the thing was great. I've since got rid of the DC 30 when I was given Studio 9 & Pinnacle Capture card as a gift. I've noticed to Studio 9 doesn't seem as flexible as the software for the DC 30 was. I was using VirtDub & TmpGenc & others. I think I can load new codecs that will offer more flexibilty for Studio but don't know how. The manual only says others can be used but not how to load them. Can y'all tell me how to do this and recommend a few good ones? I'm doing basic capture & editing.
Also, can you recommend a good cap card for around $200ish? thanks.
The DC30 captured to MJPEG using hardware encoding. So I assume you were editing MJPEG in Virtualdub?
The Pinnacle capture card is probably just a simple Connexant chipset without any hardware encoding. Normally you would capture uncompressed, edit, then encode to DVD MPeg2 or Divx/Xvid or something else. Some capture with software encoding to MPeg.
MJPEG isn't used much anymore. Newer capture devices capture to DV format (ADVC, Pyro, Datavideo, etc.), MPeg2 (Hauppauge PVR series is reccommended), or various MPeg4.
DV is best for editing since it is less compressed and contains all frames. MPeg2 needs a specialized editor or needs to be decompressed for editing. MPeg4 always neeeds cecompression (lossy).
For DV - ADVC-110 This is the best price I have seen
http://www.bhphotovideo.com/bnh/controller/home?A=details&kw=CAADVC110&is=REG&Q=&O=pro...ist&sku=349146
For MPeg2
http://www.pricegrabber.com/search_getprod.php?masterid=3017802&search=hauppauge+pvr+usb2
How Can I Add Codecs to Pinnacle Studio 12?
By slalomchip in forum EditingReplies: 6Last Post: 7th Sep 2011, 19:47 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
