I was using Nero to convert and burn, but 2 out of 4 DVDs were coasters.
I switched to converting with Nero and burning with Imgburn. Not so many coasters but still losing some.
I found that I could burn the first DVD no problem, but if I tried to burn another straight away it failed.
If I restart the computer after every burn, I get 100% success rate.
Any ideas why it does this?
It sounds like a buffer is getting filled up and not refreshing, but that's just a guess. Or it may just be that your burner is overheating.
Personally I wouldn't use Nero for anything but burning. It doesn't do that well as an encoder/converter.
You never said what was wrong with the DVDs. If Nero failed to complete the burn, there would be a burn log to give you the error. If it's just a burning problem, I would try different media. You should be having zero coasters. If you still have the problem with a different encoder, different media, and a different burning program, maybe there is a problem with the burner? -
Overheating!Originally Posted by redwudz
I just vacuumed out the inside of my computer. Fans were getting clogged again!
That should ease some problems.
Back to burning...
If I restart after every burn I get 100% success. I can do that 50 times. But the minute I try to burn another DVD without restarting it fails after 'writing leadin' -
Do you have the same issue with both apps or just one? If it is both apps, I would suspect the drive.
Google is your Friend -
Yes same issue with Nero and Imgburn.Originally Posted by Krispy Kritter
BUT, after a computer restart they burn perfectly.
Just to repeat. I can burn 50 DVDs one after the other only if I restart the computer every time. So I guess DVD drive overheating isn't the problem. Wouldn't the drive give problems all the time.
I can burn audio CDs with no problems at all.
Ongoing saga of the lost MP4 thumbnails
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2011, 07:19 -
Ongoing problems with editing converting and uploading videos !
By aew30 in forum Newbie / General discussionsReplies: 78Last Post: 20th Jun 2009, 18:50 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
WANTED: Ongoing capture work
By tvtodd in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2007, 22:51 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
