Hi, I could really use your help. I'll try to describe the problem the best way I can so you can have all the info you need.
I purchased a DVD Writer (Samsung Lightscriber) recently, and I'm having some troubles burning DVDs. Using Nero, the burning stops at some point (it could happen at 10% or 42% or 70% or any time, really). The "remaining time" continues to decrease, the "total time" continues to increase, but the percentage of info burned stays the same. The software doesn't freeze; I still can hit "Stop" to cancel the burning. But the process doesn't continue and I have to cancel it or turn off the DVD Writer (external).
1) Media: it happened with both bad midia (fake TYG02) or great midia (TDK).
2) Strangely, when I went to check the firmware with Samsung Live Update, it informed me the firmware was up-to-date. However, the program identified my writer as a W162L when, in fact, it's a W164 (it says so in the back of the driver).
3) When I burn discs, I don't multitask. In fact, I always restart Windows (XP) in order to have the maximum amount of memory available.
4) I was trying to burn six huge files (4,2GB total) and couldn't do it. I don't know if it's a coincidence, but then I tried burning only five (3,7GB total) and that's when I was succesfull.
What's happening? Can anyone please help me???
Oh, one more thing: occasionally, I AM able to burn a disc successfully with 4,2+GB. But it's not common.
I have seen that with a Pioneer 109 when burning too many discs in a row at 16X. burning them at 6X it never happens. I do not know if it is a Nero thing or a drive thing.
Usually for me when that happened that would be it for burning that batch of discs until I ran a couple of different brand discs then it would work Ok for a while again. It is as if something is learning the discs wrong. -
Oh, one other thing the drive inside the external case may be a W162L but when installed into their external case it will be called something else. Massive confusion if you had internal and external drives with the exact same part number.
VCR Freezing
By koberulz in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2012, 23:40 -
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 22:37 -
DVDs skipping and freezing after burning
By rogue_edit in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2010, 14:49 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
ffmpegX is freezing! Help!
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 13:41
