I would like to have a (X)vcd with anamorphic widescreen. I'm using either TMPGEnc or CCE 2.50, and when the mpv-file is played in mediaplayer the picture gets the right A:R.
If I'm using bbmpeg to do the multplex I cant use vcd if i'ts a xvcd i must choose mpeg-1 or the mpg-file wont play properly, can bbmpeg affect the "widescreen"-mode in someway.
The goal would be to have a (x)vcd that when it's played on a standalone, signals to the tv to be in "Widemode" just like a real dvd.
I'm fairly certain you can't do this w/ the x(S)VCD discs. You make them them either permanant wide screen only, sorry. Someone correct me if I'm wrong?
The way it is know everything works, you'll only have to switch to wide manually (on a 16:9 tv). But if you only have a 4:3 tv it would be neith if you can select 4:3 in the setupmenu of the DVD-player and get a letterboxed picture as when you play a dvd-movie on a 4:3tv.
Why wasn't anamorphic widescreen mandated by the dvd specs from the start?
By yoda313 in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2010, 19:50 -
Anamorphic widescreen with TMPGenc Author Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2010, 02:26 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
Anamorphic DVD from Widescreen h.264 Video
By trueg in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 16th Sep 2008, 10:47 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
