Right now I'm using a white bedsheet. It works just fine though I'd like something that is rigid without any bunched up areas that distract from the picture.
Technically my eiko lc 330 is a 4:3 projector I believe so I wouldn't need a special super expensive 16:9 screen.
Can I get one for $50 or less? Is it worth trying ebay for a screen or is that too problematic?
I've been tempted to try to get a window screen to use but I'm not sure if I could get one wide enough to be worth it.
Any suggestions would be appreciated. Though keep in mind my suggested price range. I'm not looking to get a $1000 auto-retractable wall mounted screen. Just something portable that can be stored away easily.
Thanks.
How's about ironing the sheet ?
This tip was brought to you by http://www.tightasstuesday.com
If in doubt, Google it. -
I was going to recommend a screen till I saw your price limit.
Mine was about $350US for a 5 X 8 ft. but it works great.
Make sure you get one with a fairly smooth surface. Many of the old 8MM film type screens had a surface like a piece of coarse sandpaper and didn't work well with a video projector. -
I still haven't bought a projector yet. A number of questions and issues are yet to be answered or resolved.
I also looked at screens and noticed that much of what is offered in the <$200 canadian range is not much more than a vinyl material similar to a white window roller blind.
I plan to either order a large 97" w by 66" h blind from the catalogue for about $50 which would give a pretty large 4:3 or 16:9 unframed. Or I could use an existing spare blind I have which measures 55" w x 72" h. If I turn it sideaways it would be just about right for a 16x9 display. After experimenting with sizes, I could add a black felt frame to remove some reflected light.
The dullness of the sheet (as in non reflective) probably makes the image appear less bright that it could be on a more shiny surface although you probably have no trouble with hot spots with a sheet. -
Has anyone else tried Screen Goo? It's a special paint that you paint on your wall which supposedly has similar properties to a real screen. I installed it in a friends house and I would say it works and looks great, but I'm no videophile, so I have nothing to compare it too. It's a little costly, but it looks very professional.
My Site: The Rabbit Archive -
Thanks everyone. Interesting link bodyslide.
@ jimmalenko -
Well the problem is keeping it hanging straight off of the cabinet Im using.
I'll keep looking and see what might be ideal.
Screen for Projector?
By dfisher052 in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2012, 18:29 -
Want to moveXP Home.ed. to a new computer any advice?
By cal_tony in forum ComputerReplies: 25Last Post: 10th Jul 2011, 09:54 -
Need help with deflickering of video of projector screen
By SCDVD in forum EditingReplies: 6Last Post: 31st May 2010, 16:09 -
Question regarding Home theater projector
By jtrinc in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2009, 15:41 -
Question about home theatre projector
By mr-scarface in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 14:44
