I'm using my Powermac and downloaded some avi's that i'd like to make into a dvd. I already converted the avi's both into DVD format with FFmpegX.. From here, several files were created for each AVI. Mv2, Ac3, and MPG2 TS_Video and TS_Audio files were all created. Now, I want to burn the DVD using Toast.
Now, from what I believe i was told in the past.... I would create a UDF DVD format DVD in Toast then drop CERTAIN files into it?? Which ones? And is it possible to have them play one after another.... or have it selectable with a chapter next on the DVD player itself?
Thanks for helping a newbie out!
	If you had only one title to go on the DVD, the you could add the VIDEO_TS and AUDIO_TS folders to Toast's Data tab in UDF format. Just like the manual on the ffmpegX website explains. The data is taken "as-is": no menu and no chapter markers if ffmpegX created the VIDEO_TS folder.
 If you have several titles to go on the DVD, then you could add the .mpg files to Toast's Video tab in DVD-Video format. In this way, Toast will create a new file structure (VIDEO_TS etc.) containing both input files. Creating a menu is optional with the left panel. There will be chapter markers every 5 minutes. Continuous play is also an option there. Just like the Toast Help section explains.
	The advice about dropping the AVI's into Toast is correct.Originally Posted by sublimemike
 If you had a VIDEO_TS structure already in place (using MacTheRipper or ffmpegX, etc.), then the UDF format DVD would be the way to go. You'd set that up in Toast, create a new disc, and drop the VIDEO_TS folder into that new disc. Burn.
  How can I rip DVD to AVI and make each chapter a seperate fileBy mikeyshine in forum DVD RippingReplies: 10Last Post: 23rd Sep 2011, 15:02
  Help. What program to use to make avi files play on dvd player?By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 18:09
  Combined 2 discs into one, but disc won't play on dvd-player...By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24
  DVD - How do I make all files play automatically?By gina_here in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:25
  Putting 2 QT Files w/ 2 seperate .srt files onto a DVDBy whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
