After reading many reviews for Firefox and how it handles standard codes whereas IE accepts more codes that are actually non-standard, I can begin to understand that Firefox is actually pretty good.
I have a blog page that was written when I still used IE and it looks good in IE. The blog layout is a template from Wordpress that uses tables and I did not alter anything there. However, when I added my own table on an individual page, it does not look correct in Firefox. The images became really small and not to mention, it messed up the blog template somehow by looking at the bottom of the page.
http://three-lights.net/full/?page_id=38
I've rechecked my table HTML code and it seems correct. So what is wrong with it?
The W3 validator says you're wrong...
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fthree-lights.net%2Ffull%2F%3Fpage_id%3D38 -
I have checked every thing that site told me to fix. For instance, all of them are saying I am missing a < or a > but I've checked and it's there.
It is definitely Wordpress's input field's problem. It allows you to type in HTML codes but at the same time, if you press enter twice, it'll act as a break even though you didn't put in a break tag. It's messing up all my HTML tags.
I've copied the exact same code which I entered into Wordpress and made a separate HTML file to view in Firefox and that works fine. -
I don't see anything wrong with that page. Firefox 1.5.
The only thing that keeps it from being 100% valid at the time I post this is that you're using a id="top" twice.His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I don't recall ever using that, so it's probably somewhere in the blog template beyond my tampering. But I have redone the table and it shows up in Firefox fine. I have deleted the page for now to redesign the tables. I must brush up on my table skills.
Edit:
I noticed Firefox also does not accept the colored scrollbars in CSS coding. Why is that?
DLC.html
By Hangrumps in forum Video ConversionReplies: 4Last Post: 15th Jul 2009, 15:00 -
7z.html files???
By Glenn5782 in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2009, 04:43 -
html help
By steve42069 in forum ComputerReplies: 4Last Post: 8th Aug 2008, 10:38 -
HTML Help
By FEEL in forum ProgrammingReplies: 3Last Post: 20th Aug 2007, 08:58 -
html in forum
By Ogilvy in forum FeedbackReplies: 4Last Post: 13th Jul 2007, 18:30
