hey all. I got an asf file recorded from online radio. its over 7 hours, and about 200mb. but when i open it up in wavlab, it says it cant open a file larger than 2 gigs. ( I assume the temp file as a wav)
what can i use now to convert this to something i can use??? (asf is useless in an mp3 media player)
Heh - I think there are some MP3 players (and DVD players) that do recognize ASF. If they recognize WMA, they may recognize ASF as well, since ASF is the previous generation of WMA.
Offhand, I think you can try ASFTools, or better yet, SUPER (which is, of course, a GUI to ffmpeg, mencoder, etc., so if you're not adverse to the command-line, you can try those as well.).If cameras add ten pounds, why would people want to eat them? -
Directly converting asf audio file to Mp3 is not possible, all you have to do is first play the asf audio file and then record using a software (try Fleximusic wave Editor) and now save the recorded file as mp3/wav format.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 06:02 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 07:32 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 20:07
