    Jun 2006
    Canada
    Hi,
    I’d like to make a single DVD disk from a movie that is on two DVD disks.
    The plan is to remove all the menus, extras and languages except English with DVD Shrink as I do not need the stuff. As a result I will get two separate parts of the same long movie.
    How can I join the resulting two parts/movies into one for further burning on a double layer DVD disk?
    Thank you!
    you can join with dvd shrink using the reauthoring mode, https://forum.videohelp.com/viewtopic.php?t=284279
    Jun 2006
    Canada
    Thank you!
    I did not know that DVD Shrink can do this.
