    May 2005
    Far from Heaven
    Hi, My sister has a newborn. They want to be able to see the baby from another room also (in both rooms there's a computer).
    So I put a web camera in the baby's room, plug it to the computer that is in the same room.
    The question is - what sofware is needed to be able to see on that web camera on another computer that is on the same lan?
    Thank you.
    Arguing with an idiot, make sure he isn't doing the same
  2. Member CrayonEater's Avatar
    May 2006
    Why not just use a webcam?
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951871&CatId=130
    This may help if streaming software isn't included, but you can probably get freeware stuff:
    http://www.commercialnetworkservices.com/streamingmedia/howtosetupawebcam.htm
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Two options
    Window Media Encoder 9 (see Baldrick's Guide) with WMP or another player.
    http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
    VideoLAN server and player (see guides for set up)
    http://www.videolan.org/vlc/
