can someone tell me where i can find a guide to do this, either with VirtualDub or VirtualDubMod
also why cant VirtualDub or VirtualDubMod save as .mpeg
thanks in advance![]()
Closed Thread
https://www.videohelp.com/tools?tool=Virtualdub and look to the bottom of the page, Lots of guides for VD.
VD is a AVI format program. If you want to save as a MPEG, you will need a MPEG encoder. If you have an encoder like TMPGEnc or a few others, you can frameserve the edited output directly to it and avoid a in between file.
There is a codec, YMPEG, that will work with VD and produce a MPEG output.
EDIT: Note that YMPEG is payware and for a few dollars more you can get TMPGEnc encoder that will work with VD when using a frameserver.
Wasn't this asked and answered here: https://forum.videohelp.com/viewtopic.php?t=306298 ?
If in doubt, Google it.
well we all make mistakes as the hedgehog said to the wire brush
I have copied a vhs to my pc but trouble is there is comercials in it and if I cant see movie to where I want it cut how can I do this as in VirtualDub when I click preview input or even filterd the movie is playing ok but I need to move it in parts so I get to where 1st part ends. yes I have looked at previous posts and was going to ask this but had forgot, like I had also forgot about top of page here too. if anyone can understand what I mean please reply as I cant find anything that will let me move movie to where I want, unless I dont have VD set up right.
sorry if I have annoyed anyone here
Editing parts of the audio on VirtualDub
By ione in forum AudioReplies: 5Last Post: 19th Sep 2008, 05:57 -
Is VobBlanker good for cutting parts off of VOb files???
By mabhz in forum EditingReplies: 5Last Post: 28th Jul 2008, 04:01 -
Cutting WMV into multiple parts
By craigy27 in forum EditingReplies: 3Last Post: 4th Jul 2008, 05:45 -
Cutting video to several parts without encoding (on Unix system)
By Doctor_X3 in forum EditingReplies: 0Last Post: 23rd Feb 2008, 15:23 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 15:09
