Results 1 to 9 of 9
  1. i know leopard is in Developer preview still but i was just testing out some apps and i noticed that ffmpegx doesnt seem to work right in Leopard. When i try to convert a VOB to xvid the main ffmpegx shows that there is no video or audio in the VOB. but when i click on the info button it shows all of the correct info for the vob, just wondering why this? No rush on this either im sure you are pretty busy major.
    Any progress since your original post? I'm preparing to buy a new iMac with Leopard.
    Thanks!
  3. Just tried to convert a VOB to XviD in 0.0.9x with Leopard and works normally.
  4. In my experience, using Leopard , I have this problems:
    Bottons: rate dur opt auto dim img returns errors.
    Any help ?
  5. Found the issue, will fix it in 0.0.9y.
  6. Fixed the errors on the bitrate calculator buttons. I will release a repackaged 0.0.9y shortly.
  7. Great Major !!!!
    It'is a very annoying issue !!!!!
    I'm anxious to have the patch !!!!
    Thank a lot.
  8. Any news about repackaged 0.0.9y???
