I've converted a MPEGII file using DGIndex... It created a .mpa file, and when I load that into ffmpegGUI and try and convert to AC3 I get the following:
What am I doing wrong here?ffmpeg version 0.4.9-pre1, build 4743, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-vorbis --enable-faad --enable-faac --enable-xvid --enable-mingw32 --enable-a52 --enable-dts --enable-pp --enable-gpl --enable-memalign-hack
built on Feb 22 2005 04:58:29, gcc: 3.4.2 (mingw-special)
F:\tmp\DGindex-ouput\Untitle T01 DELAY 0ms.mpa: Unknown format
change the extension to .mp2
no problem.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 05:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 23:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
